Making an s14
BIGreading
If a s14 is a m10 block and a m88 head with 2 cyclnders took off , has any one made a home brew s14 or there abouts ?
Reelizmpro
I have heard of people combining M10/S14 parts and turbocharging it but I don't think anyone with an M88 head will actually lop off 2 cylinders, block off coolant passages, etc. to build their own S14. Besides, one would probably have a better chance of finding genuine S14 parts with all of the engine swaps people are doing.
ross_jsy
Why would you bother when you can buy an s14 for £2-5k?
teamalsoran
s14 and m10 blocks are very similar but not the same, s14 has an extra oil drain at the back, so if you tried to fit an s14 head on an m10 it would leak oil all over the place, i've had the same issue in reverse when using an m10 head on an s14 block and had to plug the hole in the block.
the really big difference is that s14 bores are Siamesed, in otherwords there is no coolant passage between the cylinders, this allows an s14 block to be bored much bigger to almost 96mm, an m10 block is on its limit at 92mm
Demlotcrew
There are many more differences than that!
ajay
Even if it could be done it will never be better than an s14 or worth the same as an s14, realy no point at all.
