Found water in my boot, needed a jug to remove most the water, how do i stop this from happening..
Left fog light is in a sorry state, could i clay bar it back to health or is it good as gone..
Check/replace the rearlight seals.kangman wrote: Found water in my boot, needed a jug to remove most the water, how do i stop this from happening..
This is what it should look like Kangman..kangman wrote:A friends e30, this has snapped on his electric roof what needs fixing, replacing??..
diable wrote:Listen to Gert, he's the Zone's expert on electric roofs.
Take a look at the Real site for your own thoughts, but that's what it looks like to me. Unfortunately, looks like it's part of the lever, so may be supplied (read expensive) that way..kangman wrote:yea i think the securing bolt has snapped, is that part number 4?
diable wrote:Are you able to get yours up now Gert, the roof I mean?
Gert, are you sure that yours is the right way up?Gert_8 wrote:This is what it should look like Kangman..kangman wrote:A friends e30, this has snapped on his electric roof what needs fixing, replacing??..
so what item numbers need replacing? and should i attempt this on my own or give it in for repairs?willnz wrote:It is, unfortunately, part of the lever, so the whole lever with shaft has to be replaced. You will find the securing bolt/screw is still OK.Gert_8 wrote: Take a look at the Real site for your own thoughts, but that's what it looks like to me. Unfortunately, looks like it's part of the lever, so may be supplied (read expensive) that way..
kangman wrote:so what item numbers need replacing? and should i attempt this on my own or give it in for repairs?willnz wrote:It is, unfortunately, part of the lever, so the whole lever with shaft has to be replaced. You will find the securing bolt/screw is still OK.Gert_8 wrote: Take a look at the Real site for your own thoughts, but that's what it looks like to me. Unfortunately, looks like it's part of the lever, so may be supplied (read expensive) that way..
