325 oil cooler,pre/post facelift.Are they the same?
technoviolet
Post Sat Nov 26, 2005 6:29 pm
Can someone tell me if there is any difference between the oil cooler on a pre facelift sport and a post facelift,ie mounting brackets etc.I need a cooler and can get hold of one in good condition but it,s off an early sport.Need to know if it will fit ok.Cheers in advance guys.
Demlotcrew
Post Sat Nov 26, 2005 6:32 pm
Yes they mount to the car with different brackets.
You can fit both to later cars tho.
Andrew
technoviolet
Post Sat Nov 26, 2005 6:47 pm
Thanks andrew.So it will just be a case of altering the brackets to fit the cooler to an 89 model?
technoviolet
Post Sat Nov 26, 2005 6:53 pm
Also,are the pipe fittings the same on both? 1/4 bsp or metric size?
Templ8e30
Post Sun Nov 27, 2005 12:08 pm
I have a combo on my 2.7, pre-facelift cooler and pipes with facelift take-off plate :mad:
The facelift cars have the mounting points for both types. The pipes are the same thread size.
Pre-facelift parts here http://www.realoem.com/bmw/showparts.do ... g=17&fg=05
Post facelift parts here http://www.realoem.com/bmw/showparts.do ... g=17&fg=05
Cheers,
Iain T
2007 Mazda 6 2.0 estate
technoviolet
Post Sun Nov 27, 2005 4:44 pm
Thanks Iain T,ill go ahead and get the cooler so.Im looking forward to sorting out the oil leaks on the car,all i need to get now is a seal kit from the stealers for the filter head :mad:
Templ8e30
Post Sun Nov 27, 2005 7:39 pm
If I were you I'd buy 2 of the o-rings (part 15 for early and part 4 for facelift) for the take-off plate connections to the oil cooler pipes. They fit on the end of the pipes and are invariably knackered or missing.
I'd also fit it before you change the oil and use some engine flush to dissolve the crap inside the cooler.
Cheers,
Iain T
