e30 cab air con removal
lamby
my 87 320 cab is getting crushed,taking things off but just wondered if theres any point in removing the a/c money wise?
Topblag
oh yes, a full AC system is worth a full hundred pounds.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
lamby
does the wiring unplug? and can i demolish the dash too aid removal as i don,t want to faff too much.
suedenim
I wouldn't personally based on experience. It's a miserable job to remove complete and intact and stuff like the compressor are only any use if they run on R134a(?) gas, probably doesn't. If you have the time, patience and the ability to sit on the parts long enough that someone might be mad enough to retro fit, your biggest benefit would be knowing how the system works, is installed and how it could be repaired in the future. Removing the heater box is probably one of the nicer parts of it, and no smashing up the dash isn't the best route, if you're thinking that way the job probably isn't for you. Keep the switches and any thing else that's easy to remove.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Having removed several complete air con set ups and also retro fitting several i would say the heater box is the most awkward part.suedenim wrote:I wouldn't personally based on experience. It's a miserable job to remove complete and intact and stuff like the compressor are only any use if they run on R134a(?) gas, probably doesn't. If you have the time, patience and the ability to sit on the parts long enough that someone might be mad enough to retro fit, your biggest benefit would be knowing how the system works, is installed and how it could be repaired in the future. Removing the heater box is probably one of the nicer parts of it, and no smashing up the dash isn't the best route, if you're thinking that way the job probably isn't for you. Keep the switches and any thing else that's easy to remove.
Some of the compressors that have on R12 can also be run on R134a, infact the compressor in my very own E30 was originally an R12 one.
A handful of people on here have retro fitted air con and second hand kits start at about £200 for one with rough pipes and condenser to over £400 for one already converted to R134a and in a working condition before removal.
If the temperature control knob is electronic and not cable operated then this makes up part of the rare "regulated temperature control" system or climate control.
This will also increase the value of any system being sold.
What most people fail to realise is that you CAN NOT have working air con retrofitted and blowing cold using you average secondhand kit and a few hours work.
But to answer the OP's question, yes i would remove it if fragging a car.
Topblag
Have you done the conversion from old gas setup to the recommended replacement kit Barry ? Any idea how much the kit costs ?
My Hartge and IX both have aircon and I want to have them converted to a legal setup. They both need re-gassed anyway.
suedenim
Kits are shown on realoem iirc.Topblag wrote:Have you done the conversion from old gas setup to the recommended replacement kit Barry ? Any idea how much the kit costs ?
Whatever is the easier and harder part of pulling the kit complete, I still wouldn't advise someone who asks whether they should liberate it by smashing it out to do it.
lamby
kit is shown on the wiki so looks straight forward enough.
hammertime
hammertime
