couple of Qs for the M30 Gods
jimbom30cab
Tech 1 freak
Post Sun Nov 11, 2012 8:44 pm
you see the rubber hose, bottom right, looks fooooked, i've been trying to find the part number on REALOEM but can't find it anywhere, probably me being thick - anyone know?? should replace the small middle hose also i think
Having the same problem identifying an e28 535 bottom rad hose, anyone know the part number or have a link please?
same issue with the M30 vacuum hoses, they seem expensive through BM but must be off the shelf hoses, anyone bought replacement hoses and have a good recommend?
thanks M30 Gods :D
maggspower
Turbo Farmer Tractor Driver
Post Sun Nov 11, 2012 8:51 pm
http://realoem.com/bmw/showparts.do?mod ... g=34&fg=27
May or may not be the right one, look in the brakes, then servo section. But put the donor details in, I just put, e34, 1989, auto,RHD.
maggspower
Post Sun Nov 11, 2012 8:54 pm
jimbom30cab
Tech 1 freak
Post Sun Nov 11, 2012 8:56 pm
thanks mate, that's about as far as i got also but struggled to ID the lower hose and also the knackered rubber servo hose. any idea on the part numbers ??
maggspower
Post Sun Nov 11, 2012 9:03 pm
First thing is you need to put in the details of your vehicles or donors to realoem.com
I have just picked an e34 and e28 at random, parts change depending on year auto/manual etc, others stay the same.
jimbom30cab
Tech 1 freak
Post Sun Nov 11, 2012 9:05 pm
yup did that, got to the same page as you, you guessed dead right btw, i just wanted to confirm the part numbers, thanks
jimbom30cab
Tech 1 freak
Post Tue Nov 13, 2012 11:31 am
right, i've got the e28 bottom hose sorted now thanks, but still struggling to recognise the broken rubber hose in the REAOEM parts site, any ideas on part number ??
