TIA
Best type and place to buy a battery conditioner
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
As topic. Please advise.
TIA
TIA
For the car or for the batteries used by your myriad of 'toys' ?
Gert_8
LOL. Car one for the moment please.
Rtaylor2208
Maplin have this on special, it won't charge from flat but it will keep it topped up:
http://www.maplin.co.uk/solar-powered-1 ... rger-98358
Gert_8
Won't work mate. Car's in the garage over winter so won't get much sun. I think I need a conditioner type. I usually disconnect the battery, but I don't think it does some of the cars systems much good
Thank you.
Thank you.
I have the C-tek one - works a treat - started my car today for the first time in over 2 months with no dramas
They are about £40
They are about £40
Gert_8
Is there a model number you would recommend please?
Rtaylor2208
It comes with a pretty long cable, I have my cab garaged as well and the cable ran out through the eaves of the garage with the solar part on the roof.Car's in the garage over winter so won't get much sun
Worked all last winter and so far so good as the cars not been used since the start of october.
Gert_8
@ Rtaylor, I have a charger, but if that is left connected it buggers the battery. Does the solar charger not work in the same way as a normal charger?
oomz1975
As above...capri_rob wrote:I have the C-tek one - works a treat - started my car today for the first time in over 2 months with no dramas
They are about £40
http://www.ebay.co.uk/itm/CTEK-Multi-MX ... 19c8e9daf8
One of the best investments you can make.
Rtaylor2208
Its just a conditioner, so once fully charged it stops, if the battery drops below full charge it will charge again. I've had no issues at all with the battery so far. And the cab is hardy ever used so the charger is pretty much attached all the time.
Gert_8
This one looks good. Plug in and forget about it. I'll order one on Monday.oomz1975 wrote:As above...capri_rob wrote:I have the C-tek one - works a treat - started my car today for the first time in over 2 months with no dramas
They are about £40
Thanks fellas.
Gert_8
Well that's the best endorsement so far, so I'm definitely getting one!diable wrote:I have a C-tek one as well.
kieran325
I've got 2 C Teks, a posh one about £100 and a not so posh one for £40, can't see the difference and they both do the same job IMO.
I bought 2 C Teks off eBay and I went to buy another one from the same seller, he didn't have the model I wanted and gave me the super duper one, like I say I can't see the difference.
Kedge
I just use one Oxford one I've got for the motorbike, think it was £19.
Gert_8
Bought one guys. Thanks very much for the help.
