Front fog lights not working,
baxter-e30
Post Fri Nov 09, 2012 1:05 pm
followed the wiki fitting guide on here on how to fit fogs.
fitted the front n rear fog switch,
fitted the k8 relay and fuses to 29&30
fitted the front fogs.
No luck!
any ideas?
Rich320I
Post Fri Nov 09, 2012 1:07 pm
does the tell tale light come up on the dash?
it may be the switch itself that is at fault, it easily cleaned with some contacr cleaner though and happened to be the problem with mine
baxter-e30
Post Fri Nov 09, 2012 1:11 pm
i havent put the bulb in the cluster yet tbh,
i think the switch maybe at fault as when i changed over the switches and put my lights on full. the rear fog light is constantly on. but can be turned on/off when on dipped lights.
need to get hold of another switch now and give it a try
Rich320I
Post Fri Nov 09, 2012 2:13 pm
id give cleaning the switch a try, the switches are very very robust and normally just need a clean.
baxter-e30
Post Fri Nov 09, 2012 2:21 pm
Rich320I wrote:id give cleaning the switch a try, the switches are very very robust and normally just need a clean.
just bought some contact cleaner you mentioned of. il try it now and let you know how it goes
Rich320I
Post Fri Nov 09, 2012 2:43 pm
It should de the trick mate, the switch is probably stuck was exactly the same symptoms in mine. Hope it sorts the prob bud :D
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Nov 09, 2012 3:39 pm
You should be able to unplug the switch and bridge the wires to make the lights come on, to confirm that it is the switch.
baxter-e30
Post Fri Nov 09, 2012 4:00 pm
ive cleaned all the contacts on the switch and its still doing it.
im gonna try another switch me thinks. shame as ive got everything fitted now to have front fogs
