exhaust/6branch help
dazleeds
old skool raver
old skool raver
Post Fri Nov 25, 2005 5:29 pm
ok just got a 6branch manifold and the front pipes
i also have a tidy scorpion backbox
but i need a new middle section
so whats the best to go for??
at sensible money that is dnt wanna spend much more now just want it all nic and new
cheers
Daz
www.oldskoolfantasy.co.uk
keith52
Post Fri Nov 25, 2005 7:34 pm
Same as myself , my problem has been that the centre box from german swedish has the same diameter bore as the scopion so i had to get 2 sleeves of a larger diameter , not a job i'm happy about , when the weather improves it's coming off and i'll get the sleeves tig welded to the rear box and remove when set of u bolts currently fitted, as regards the 6 branch , no problems with it
dazleeds
old skool raver
old skool raver
Post Fri Nov 25, 2005 8:06 pm
keith
what box did you get??
thats what i need to know
heard the standard boysen box is good
but dnt wanna get it wrong and waste cash
but need something in there to quieten everything down a bit and keep things legal
keith52
Post Fri Nov 25, 2005 8:18 pm
Daz . i believe it's a boyson, except for the fitting problem the centre box is fine , the noise levels are minimal and imo dosn't attract attention which is fine for me Make sure that which ever make centre box you buy has the rear bracket to fix the hanging strap to as the scopion rear box is a really hefty piece of kit and you can't rely on the 2 rear straps which go around the rear box to keep it up Hope this makes sense to you
E30Mark
Post Fri Nov 25, 2005 8:50 pm
keith52 wrote:Same as myself , my problem has been that the centre box from german swedish has the same diameter bore as the scopion so i had to get 2 sleeves of a larger diameter , not a job i'm happy about , when the weather improves it's coming off and i'll get the sleeves tig welded to the rear box and remove when set of u bolts currently fitted, as regards the 6 branch , no problems with it
Pop into any exhaust centre they should be able to 'expand' any pipework so that you can slip the exhaust parts together
PM for details
keith52
Post Fri Nov 25, 2005 9:04 pm
Cheers Mark , i'm waiting until i get my transplant sorted then it will all be done in one big hit
