Grinding from Blower Motor
yung-gun
Post Mon Nov 05, 2012 11:42 am
Hey guys, i've got a grinding/contacting noise coming from the blowers. they intermittently work on 1,2,3 but always work on 4.
Any ideas what it would be? need a bit of lubrication in the motor?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Nov 05, 2012 11:43 am
Exactly that. Get it lubed before you burn it out.
yung-gun
Post Mon Nov 05, 2012 11:51 am
Fair shout! thanks matey
paps78
Post Mon Nov 05, 2012 12:49 pm
Hi i have the same problem. how do you do get access to this? Through the engine bay or underdash?any thing special to use?
yung-gun
Post Mon Nov 05, 2012 1:01 pm
It's accessible through the engine bay.
http://www.e30zone.net/e30zonewiki/inde ... nly_on_Max
paps78
Post Mon Nov 05, 2012 1:19 pm
yung-gun
Post Mon Nov 05, 2012 1:21 pm
paps78 wrote:Hi i have the same problem. how do you do get access to this? Through the engine bay or underdash?any thing special to use?
You broken? lol.
Just read this matey it'll tell you everything you need to know
G-Bear
Post Tue Nov 06, 2012 8:59 am
Just did this yesterday, once you've got the motor out, carefully hoover out all the crap thats collected in there over the years and have a good look for any rot along the scuttle.
A very enjoyable little job that, was nice not to be on my back under the car for a change, cursing/straining whilst holding something in place and trying to create some extra joints in my fingers to get a nut back in place..
yung-gun
Post Tue Nov 06, 2012 1:57 pm
Ah damn! Just done the above and it has improved it from what i was, however i have gripped the blower fans and the whole shaft wobbles. anyone know what type of bearing it is? bearing race, plain bearing
Post Tue Nov 06, 2012 8:14 pm
You need to stand the motor on end, drip oil down the motor shaft and move the motor until it runs free and then turn it the other way and do the same at the other side
You may need to repeat this several times before it runs how it should
Getting the metal clip back in when you put it back in the car can be fun :x
yung-gun
Post Tue Nov 06, 2012 11:12 pm
I understand lubricating the dry bearing. but the shaft rattles as if the bearing has gpme
Post Tue Nov 06, 2012 11:49 pm
yung-gun wrote:I understand lubricating the dry bearing. but the shaft rattles as if the bearing has gpme
Run it dry for long enough, and it might well be. If you attend to the bearings' requirements when they first start giving notice, then lubrication will solve the problem.
Quite a bit of sideways movement is normal, but any movement at right angles to the shaft signifies a scrap motor.
yung-gun
Post Wed Nov 07, 2012 8:47 am
It's all around movement so i'm 99% sure that the bearing will have gone. i'll take the motor out and see if i can source a new bearing. thanks everyone!
