radiators
shadrack
can i fit a facelift 325 rad to a pre, or can i put the 318i facelift rad i have in the shed on my 325, size wise its loads bigger as i have the auto rad on still at mo after manual con, its got tank on side of it though and the pipes are to different sides but will fit
mcbonio
I guess you can fit what ever radiator you like as long as it mounts securely and you have pipes long enough to reach as you say, the prefacelift radiator hoses connect to the top of the radiator and the facrlift radiators connect to the sides.
