After 3 months of hard work was not what I was hoping for! It's running lumpy like a tractor I replaced a ht lead with my old m40 but switched it back but it's basically shaking the whole car..?
I did a motronic 1.3 conversion as well, I grounded the green black off the starter and the heaters worked.. Really need the car today as I'm going on hol
Check the connector plug to the injectors under the inlet manifold; corrosion or broken wires often set in so you only get half the injectors firing, or worse, none at all.
ECU Upgrade EPROM Chips, £40 posted within the UK. Note these are not Zone chips. viewtopic.php?f=6&t=279421
Speedtouch wrote:Check the connector plug to the injectors under the inlet manifold; corrosion or broken wires often set in so you only get half the injectors firing, or worse, none at all.
2, 4 and 6 are one complete set, so the above is more than likely.
Fuels getting through defo, I removed the plugs and they were wet just no spark on 2 4 and 6 I used my old m40 leads and replaced two as they were looking oldish replaced with genuine bremi leads though?
I'm using the original injector electrical connectors though of that makes a difference? Posted a thread up if there was a different between motronic 1 and 1.3?
Missed that bit Injector loom clipped onto the injectors properly, i did this with my m30 more door, ran lumpy on 5 all it needed was a firm press down on the injector connectorand all was good
Don't know what I've done but tinkering with it it's now sparking on all 6 but still lumpy, only other thing I can think of is timings out somehow? Or firing orders wrong
Perhaps try a new ignition coil, or at least check the connections to it.
If the ECU has been opened up, it is possible there is a fault with the spark driver transistors on cyls 2, 4 and 6. Which ECU is it, e.g., 0 261 200 173.
Yep 173 ecu mate, I've opened it up again and inspected it can't see any issues no burnt out resistors or anything, I've gone around used connector cleaner on all connections it's now sparking on all 6 I've changed the fuel injector loom to the one I got with the motronic 1.3 kit and it seems to idle and run slightly better,
However its still shaking the car as if it were misfiring or running on three when I open the throttle it hesitates and drops,
Don't forget you should initialise the ECU by letting it idle for at least 10 minutes to enable base idle settings to be learnt, then switch off, then take it for a drive thoughout the rev range.
If you haven't done this, disconnect the ECU or battery for an hour or so to reset it, then go through the initialisation procedure.
cool so its not that, i kept the coil as it was pretty much brand new,
yeah i was just gonna quickly pick a set from halfrauds see if it makes a difference, either way if it improves or stays the same il return them, its just i need them fairly asap! il see if i can pick some up along the way,
tps and ivc were working fine as it was all removed from a working car i bought and drove, will give it another clean tomorrow though,
havnt managed to get ht leads as halfrauds wanted £167, i gave the c191 plug a shot just rereouted the B/Y B/W and R/W wires together directly and plugged the rest of the plug in,
i basically tested the injectors on ignition and cranking prior 2 4 and 6 were at 0.24 whilst 1 3 and 5 were at 11v,
those were the three coloured wires per injector so i hard wired them and sounded slightly better but now theres a whistling noise and a knock and a puff after about 20seconds bad misfire,
I presume you fitted the Motronic 1.3 setup in its entirety, complete with the CPS, and removed all the old Motronic 1.0/1.1 stuff (which had two CPS sensors)?
