Who nowa any info on props for 335 conversion on a touring
35Touring
Post Mon Oct 22, 2012 8:36 pm
Hi guys need abit of help again......... lol nearly there...... i baught an e30 320 prop for my e30 335 conversion running m10 box as some1 said it would fit... it was too sort :( about 50mm short .... i was goin to pull the prop apart 50mm but the center bracket doesnt line up when you do this the holes are out... i was thinking custom mount the center bracket and pull prop apart 50mm so its sitting on half the middle spline but am not sure if that is the best way.. or can i double up on the rubber prop mount would this work...
Thanks for the help :)
TPS
Post Mon Oct 22, 2012 8:38 pm
Rav will know.
leeparkes
Post Mon Oct 22, 2012 8:51 pm
As said through pm you need to measure from diff flange to gearbox guibo, but first measure the prop you have, 320i prop should be 1526mm.
Is the engine in pos 3?
35Touring
Post Mon Oct 22, 2012 9:07 pm
Yea engine is as far back as it can go pos 3.... i took the prop off a 320 in a breakers yard so gotta be right lol... is the prop the same in saloon to touring .. !!!
leeparkes
Post Mon Oct 22, 2012 9:10 pm
Yes there the same but auto/manual are different.
