e30 g reg m3
pla
hi i wantto put some wheels on m3 e30 m3, the wheel are 18 inch bbs 2 piece off a 5 series bmw, they measure 8j x 182 235/40/18s will these go on all around. or will they catch on the front, what is the most i can put on the front or back and the tyre size. thanx
Fushion_Julz
The critical bit is the ET number or offset...
You'll need to know this to work out the clearances, but I suspect you'll have a problem with the tyre hitting the rear of the arch at full lock...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Ant
- Retired Team Member
if the tyre/arch do run close the offset bushes should help with this.
worked on a couple with 850Csi rims , both had offset and no rubbing issues even under hard cornering loads.
Email FTW
