Evening all
Need some help, as title suggests my key is stuck in the ignition between p1 and 2
It wont return to 0 so I can remove it
Any suggestions?
Stu
Help- key stuck in ignition
bigwinn
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
BATTS91
May sounds obvious but push and pull the key out a little while turnin ;)
bigwinn
pushed, pulled, hit, punched, etc etc
still stuck
still stuck
jonny323i
lots of wd40 in the whole and see if it frees it off!! never tried it but worth a shot
Touring for life
bigwinn
tapped with a screwdriver ten times
worked
think i need a new lock set- after the door drama and now this
worked
BATTS91
Then im out of ideas , a pals used to get stuck in the start position with starter spinning if the key had pressure on it while turning . Just push it in again to get unstuck
bigwinn
all done- screwdriver fixed it
