Hi guys, I have a problem with my e30 m30 conversion. I've been running the m30 for 1 year now. Recently it developed a misfire at 2000 revs and occasionally cuts off totally. When it cuts off it proves to be a nightmare to get going again even had to get the aa out twice.
I get a spark and the fuel pump is working but not sure if the injectors are opening.
Any suggestion will be appreciated.
e30 m30 conversion
maggspower
- Turbo Farmer Tractor Driver
My first suggestion is get a smaller avatar.
Then check the crank sensor on your motor
sag
maggspower wrote:My first suggestion is get a smaller avatar.
+1
