Tramlining and poor steering self-centering
Cloggy Saint
have your front struts ever been re-built ?
- Lozzas318is
Have u had the wheels realigned? Tracking may b out. Or the top shock mounts could b binding up which can result to this, so changing top mounts and mount bearings
Cloggy Saint
Cloggy Saint
- Brianmoooore
Check yourself; don't rely on some fancy laser set up - it may be accurate tp +/- 0.00001 degrees, but the operator might only be good for +/- 5 degrees or so.Jos wrote:Sounds like too much toe-out, alignment check 1st then look for other problems.
