castrol 80w for gearbox 325
bmw9818
Post Tue Sep 25, 2012 1:52 pm
mcbonio
Post Tue Sep 25, 2012 2:38 pm
I used this on my e46, at first it seemed great. Then when it started to get colder outside it became a real b*tch to shift until the gearbox had warmed up.
I swapped it for ATF and has been great ever since. As far as I'm aware, most modern manuals have ATF in the gearbox? Someone correct me? :o
Billwill
Post Tue Sep 25, 2012 3:03 pm
Pretty much exactly what we have always used on our E30s in South Africa.
Yes modern gearboxes do use ATF type fluid often and I have heard of owners using ATF in their E30s with no problems but I will stick to the original specifications. :?
mcbonio
Post Tue Sep 25, 2012 3:08 pm
It gets pretty cold here in winter Billwill, I had a lot of trouble shifting when it was cold with Castrol gear oil..
Billwill
Post Tue Sep 25, 2012 3:10 pm
mcbonio wrote:It gets pretty cold here in winter Billwill, I had a lot of trouble shifting when it was cold with Castrol gear oil..
Yes, agreed....I was just about to add that caveat to my post :D
