i have been using a elring head gasket which cost about £20 so not to costly, so my question is what stock gasket are you usingon your turbo? as im not sure elring are the best to be using
stock heD GASKETS!?...
dot
hi all, i have managed to blow the head gasket again on my m20 turbo i think its my fault for caining it too much before it been set up correctly
ross2009
elring are absolutly fine it blew coz of your tuning
what boost you running ?
dot
i have a bar spring in my wastegate, im not sure what boost it was when it blew the laptop battery went flat and it didnt record it in the log, i was thinking about getting a bmw one but if elring is as good ill stick with them
ross2009
1 bar should be about your limit safely but if it wasn't mapped then I'd say it was your tuning as to why it went pop
elring are like BMW Oem part that's what BMW use
dot
Sound, 2nd gasket in 2 weeks yay! I'm using arp's and torquing the head to 30nm +90 +90 that's correct?
ross2009
no that's not correct that's BMW spec not arp spec do them 25 lb ft 45 lb ft then 60lb ft then do a warm up run then down to 70lb ft I've got an elring on mine and I'm running about 1.3 bar
dot
i see that could be my problem, i spoke to my suplier and he said there is a thicker head gasket if your head has been skimmed does that sound right for a 8.8:1 compression engine?
thanks for your help hopefully its the last gasket for a while
ross2009
there is a thicker head gasket @ 2.05mm I think but that won't do you any favours it will still be fine up to 9.0-1
you need to get the tune spot on what management you using?
dot
I'm using vems ecu from gunni, I'm just going to repaire it and take it easy until gunni can map it, I already have the thicker gasket on order so I'll stick it on as the head was skimmed at the start
ross2009
with a thicker head gasket there even more chance that it will blow due to the thickness the head can move around more
I would have stuck with a normal gasket again personally
scjimbo
Ross bit unsure what you mean there mate. What do you mean the head will move around?ross2009 wrote:with a thicker head gasket there even more chance that it will blow due to the thickness the head can move around more
ross2009
I didn't really explain that very well there's more area on the ring lands to blow under pressure
scjimbo
Ah fair play I see what you mean nowross2009 wrote:I didn't really explain that very well there's more area on the ring lands to blow under pressure
dot
Do you think if it developed a miss fire at high speed it would cause head gasket failure?
Petka
Head gasket failiure ir rarely present due to high boost. Gasket moustly fails because you have detonation in your cylinders! Get the car tuned before you brake some internal parts of your engine. Detonation is your worst enemy!!
P.S. what afr, intake temperatures and ignition timing are you runing?
dot
Uh i have vems ecu,I don't know how to map it or the settings myself I have got this far through logging and emAils, Any how it's all back running and torqued down correctly sounds better than ever at the moment
Petka
Get it tuned, because if you have detonation problems - you'll blow another gasket (again).
You can try connecting LED to knock sensor to check realtime detonation... search google for it.
dot
its all sorted now had it tuned, should of waited first time around
