E30 doesnt sit level
retroboyo
I have noticed that my E30 doesnt sit level. The drivers side is lower. Both front and rear of drivers side are lower by same amount. Any idea on what could be causing this. I have parked it on level ground to check. Thanks.
scjimbo
knackered/wrong springs in one side
yung-gun
bmw9818
top mounts? ive got the same issue, my rear end is slanted
assume its the top mounts
retroboyo
It does seem a bit harsh if I go over even just a small pot hole in the road
mcbonio
My cab was the same, I did hear an explanation once that they where made slightly higher on the left side to compensate for the driver sitting in (what would be the drivers side in Germany) so that the car would be level with the driver sitting in. But they didn't swap this over for the right hand side cars.
Brianmoore would be the guy to ask..!
bmw9818
ey? doubt they would make wonky cars, it would alter the handling etc
mcbonio
the idea would be to level it out one you sat in.
cjdonny
sounds like one of shockers has had it? checked for leak
318 IS
TheDutch
If there's nothing obvious like a broken spring, and you never replaced them, then the dampers are quite possibly knacken.
