Hi all
Changed the cambelt and other belts on the 325 today.
Started on the nose and sounded lovely.
Took it for a run and it went very well, then halfway through the test drive it started missing badly.
Then went back to running fine, but it is what I'd describe as rattly as it comes off revs- idles fine, and sounds tappy.
Thoughts?
I think the tappets need adjusting, but not sure why its rattling at low revs
Stu
Cam Belt change- now noisy-
bigwinn
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Grrrmachine
- E30 Zone Wiki / Team Member
bigwinn
Cheers Grrrrr
- **BANNED**
After fitting the new cambelt with both the cam and crank correctly lined up,you turned the crank clockwise two full turns by hand(OK,a spanner on the crank nose!)and re-checked alignment?
Belt correctly tensioned?
Rotor arm re-fitted correctly?
Dizzy cap on correctly?
Coolant bled OK,no leaks onto the HT leads?
Youth is wasted on the young.
bigwinn
yep on all counts buddy- took my time!
I will check dizzy as thats the rattle area
Tensioner locked off properly?
bigwinn
yep- bolt done up tight
Tensioner replaced as well?
bigwinn
Yep, new one from GSF
