Steering pulling to left
greg124
Post Wed Sep 05, 2012 3:28 pm
When leaving home (requires full left lock to get off the drive) my steering has started pulling to the left.
I've found that if I briefly give it full right lock, it will centre itself again.
Any ideas?
Schadenfreude - the German's haven't got a word for that.
lamby
Post Wed Sep 05, 2012 3:53 pm
pas or muscle steering?
greg124
Post Wed Sep 05, 2012 5:22 pm
Power Steering. It does feel unusually heavy, just pulls to the left - a lot - until briefly given full right lock
lamby
Post Wed Sep 05, 2012 7:43 pm
check fluid condition and see if belt is slipping,has it just started doing it or gradual
greg124
Post Wed Sep 05, 2012 10:34 pm
The belt is not slipping, but the fluid is a bit brown.
First noticed it on Monday morning. At first I wondered whether it was due the car being jacked up at the weekend to replace the prop centre bearing, and the suspension just settling down again.
But now it's done the same thing for three days.
lamby
Post Thu Sep 06, 2012 11:22 am
check your donut by the exhaust manifold,then jack up and check springs haven,t come out of the cup thing as they can when left in the air
greg124
Post Thu Sep 06, 2012 9:12 pm
Thanks Lamby,
have checked that the springs are seated correctly. There is a small amount of play in the joint where the donut lives - a very small amount - and I don't believe that this is the cause of the problem.
What I would like to do next is set off from home with a full right lock, and see whether this results in a hard pull to the right as I go down the lane... and whether a turn to full left lock then rectifies this.
Will report back the results
