Been told that a 525 eta bottom end plus 325 head will = 2.7.
How does this work as a 2.5 + 2.5 = 2.5 ( excuse the poor maths, but you should be able to work it out!)
If this is the case.. Is it a straight bolt out/bolt in job? ( head and engine mounts trans etc)
2.5 + 2.5=2.7
kam-325i
The B25 eta engine is a 2.7 (2699cc i think.)
oze30
So is it a bolt in bolt out type of instal? What ecu do I need to use? Fuel pump etc??
320Touring
Its a fairly simple conversion, and a fair few people here are running it!
to save you waiting on responses here I'd advise you to try the "search function" at the top left of the page (just under where it says "members e30's)
It'll bring up plenty of relevant posts that'll help you make up your mind as to the best 2.7 for you
here's an example of the info available...
http://www.e30zone.co.uk/modules.php?na ... hlight=2+7
good luck!
Neil P
good luck!
Neil P
kam-325i
JazzMan
Just a thought on this subject, is it worth compiling all the information on 2.7 conversions and sticking it in the article section? It would give interested Zoners a comon point of reference? It certainly something that comes up quite often
320Touring
good idea fella! if I'm having a quiet week at work I may get onto that!JazzMan wrote:Just a thought on this subject, is it worth compiling all the information on 2.7 conversions and sticking it in the article section? It would give interested Zoners a comon point of reference? It certainly something that comes up quite often
