I had a problem with my ABS last year, the wiring that goes across the front was panel was in poor condition and as a result was throwing on the ABS lamp after moving the car.
Yesterday the lamp came on again after driving the car for 10 or 15 minutes, it resets itself when the ignition is off and your good to go again.
I think it's best to replace the entire length of cable, is it worth buying the correct spec from the dealer or can I pop down to Maplins?
