One for the technical guys..
bmw_e30_2011
Post Mon Aug 27, 2012 2:38 am
  • Hi all
    I have an e30 m30 with a irritating misfire.
    Iv done the obvious cap/arm/leads/maf/fuel pump/leads/coil/i also re-adjusted my valves which cleared it sum how for 2days and now its back...
    When i wiggle the crank sensor the misfire calms down but i tryd changin it but with now joy..
    The only thing that baffles me, when im
    Driving and it starts to miss quite bad the speedo drops off???
    Just relised it today..
    Any help would be gratefully appreciat as this i do love is geting
    On my last nerve...
    PLEASEEEE
    J
rich318i
Post Mon Aug 27, 2012 2:55 am
burn it!!! unless u want to pay the money. ECU might be fooked
bmw_e30_2011
Post Mon Aug 27, 2012 3:04 am
Not the ansa i was looking for mate...The help needed is in the title
rich318i
Post Mon Aug 27, 2012 3:08 am
bmw_e30_2011 wrote:Not the ansa i was looking for mate...The help needed is in the title
if you done everything that can be done id get the ECU checked or pay the money and get a cash in hand bmw man to run it on the bmw computer. give them £40 if fault found if not £10
poolnoodle
Post Mon Aug 27, 2012 4:53 am
Send for Dr Brian
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Aug 27, 2012 6:07 am
Ignore rich318i; he seems to think E30s somehow developed OBDII.
If your gauges act up (esp. the tacho) when it misfires, this usually indicates a power drop to the ECU. To give willnz his credit:
willnz wrote: This means the power to the ecu is dropping off, normally caused by the main relay. Check the contacts on the main relay are clean. If it still does it, try bridging the 30-87-87 contacts on the relay mounting socket. If this cures the problem, replace the main relay. If not, let us know and we will have to go through a process of elimination to determine where the fault lies.
bmw_e30_2011
Post Mon Aug 27, 2012 12:31 pm
Mate ur a legend...il try that and see what happens....
bmw_e30_2011
Post Tue Aug 28, 2012 7:02 pm
Do i bridge with the relay back back in or just bridge where the pins should go
Grrrmachine
Post Tue Aug 28, 2012 7:09 pm
Just where the pins would go
fowler
Boost Junkie
Post Tue Aug 28, 2012 7:27 pm
DME relay could be the culprit here
EX A-Tech Workshop bitch !!!
gone but not forgotten
Grrrmachine
Post Tue Aug 28, 2012 7:46 pm
DME relay IS the main relay
bmw_e30_2011
Post Tue Aug 28, 2012 8:28 pm
Brigde the relay idles better but still miss..
Grrrmachine
Post Tue Aug 28, 2012 8:39 pm
Next thing is to clarify what else you've "done". If this means "replace" then be careful; you mention "maf" but AFAIK M30s use AMF, not MAF, so hopefully you've replaced like for like from a known working donor. Regarding leads, you HAVE to use genuine BMW ones, even if they're 20 years old. Aftermarket ones just aren't up to the job. A new rotor and coil are good though.
Have you pulled out the spark plugs and checked their condition? They should all be a uniform coffee colour, so if one is lighter or smokey then you're getting a bad burn (lean/rich) on that cylinder. You may have a lean or rich running issue, caused either by the blue temp sensor (TEST, don't replace), or by an air leak in the intake system.
bmw_e30_2011
Post Wed Aug 29, 2012 12:49 am
Excuse my dumbness how do i test the blue temp sensor..yes sorry afm
Was of a running m30 engine it was a like for like swap..its defenatly running rich..its now idle ok but under load its over/under fueling....it majorly misses at a certain rpm??when i rev the car at standstill you dont hear the stutter as obvious but as soon as you pull away it cloggs n stutters??
Grrrmachine
Post Wed Aug 29, 2012 7:14 am
I don't have any direct experience with M30 engines, but their overall principle is the same as the M20. Fuelling is based on a number of sensors, and two of them can go duff; the blue temp sensor is the main one, so read about how to test it here:
http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
You NEED to test it at the ECU plug too, to make sure your wiring is sound. I've no idea what pins that is for an M30 ecu, but you should be able to find them with a search.
Other thing to check would be the throttle position switch (TPS), just in case.
http://www.e30zone.net/e30zonewiki/inde ... ion_Switch
