Quick question - HLWW System
Gert_8
Post Sat Aug 25, 2012 12:57 pm
Just a quicky....
For the Headlamp wash system, my hoses end as shown below:
But the spray nozzel has this connection:
Is this from an earlier/later system?
The metal hose end shown in the top pic will not connect to the spray nozzel. I suspec that if I remove the metal bit from the pipe, it will not go over the spray nozzel end - it is too big.
Any ideas?
Many thanks.
Sanchez
Post Sat Aug 25, 2012 1:13 pm
The plastic pipe should fit over the nozzle which sits in the grill.
Sjoerd320i
Post Sat Aug 25, 2012 1:18 pm
That plastic pipe is not for the hlww but for the leveling system.
The hoses for the hlww are supposed to be the same as the normal washer fluid lines.
jmc330i
Post Sat Aug 25, 2012 1:20 pm
I can't see the pic very well on my phone, but the pipe in the 1st pic looks more like the pipe for the headlamp aim adjuster, not the pipe for the washer nozzle.
As I said, it could just be the pic on ny phone, but if that pipe is quite firm rather than flexi, its probably for the headlamp aim.
James
'91 325i Sport
'93 318i touring 16v
Gert_8
Post Sat Aug 25, 2012 2:24 pm
Thanks guys. The hose is quite firm, but I just put that down to it being old. The fact that it ends with that metal piece would suggest it isn't for the WW.
How does the light adjuster work ? The pipe looks like there might be fluid in it?
I think these might be redundant now, as the car is fitted with hella smoked lamps, not its originals...
hennared323i
Post Sat Aug 25, 2012 3:41 pm
Pipework to the washers runs from the tank to the drivers side washer then on to the passenger side washer using ordinary washer piping and tee pieces/connectors
Gert_8
Post Sat Aug 25, 2012 5:04 pm
hennared323i wrote:Pipework to the washers runs from the tank to the drivers side washer then on to the passenger side washer using ordinary washer piping and tee pieces/connectors
Okay. Found the hose on the driver's side, which is connected to the tank. You guys are right about the type of hose, as it is exactly the same as the screen washer pipework.
My hose had been stoppered using a screw and a cable tie.. The following pic shows me feeding it though a hole in the lamps, but I couldn't connect it to the spray nozzel. It's not long enough. As a result, water pee'd out all over the garage floor and I had to re-stopper it.. :D Until I get a good solution.
I couldn't find the hose on the passenger side, and I don't know whether one exists. If you have a look at the following, you can see the pipework feeding the screen washers, but there isn't a spur off for the passenger side.
hennared323i
Post Sat Aug 25, 2012 5:48 pm
Hose to passenger side tees off hose to drivers side and is routed behind the valence in front of the rad - I expect that section will have been removed from the tee onwards and the feed plugged as you found it
Gert_8
Post Sat Aug 25, 2012 5:51 pm
hennared323i wrote:Hose to passenger side tees off hose to drivers side and is routed behind the valence in front of the rad - I expect it will have been removed
I think your right. It's not there.
The driver side
Leaked - through the spray nozzle too which
Was a little annoying ( I took the
Spray nozzle out and connected it to the
Hose) b
hennared323i
Post Sat Aug 25, 2012 6:01 pm
If I were you I would replace the lot
Gert_8
Post Sat Aug 25, 2012 6:43 pm
What consists of the lot, henna?
hennared323i
Post Sat Aug 25, 2012 6:47 pm
Gert_8 wrote: The driver side Leaked - through the spray nozzle too which
Hose) b
This sounds like the pump is leaking...swap in another one to test
I meant buy some hose and a tee piece and clips and finish the run to the passenger side nozzle - should only be a few ££'s
Gert_8
Post Sun Aug 26, 2012 3:02 pm
Thanks for your help, Henna. Good advice. :D
hennared323i
Post Sun Aug 26, 2012 4:14 pm
:D :D :D
