Getting fuel without tank to the engine
Jozi
Post Thu Aug 23, 2012 12:25 am
I need to get an engine running but I've removed the tank to get it cleaned up a bit (and pulled the mounts from the shell). Is there and easy/quick way to get everything hooked up rather than refit the whole tank and everything attached to it only to have to pull it all again when I know the engine runs?
Post Thu Aug 23, 2012 8:47 am
Use another tank on the floor next to the car with some long bits of fuel hose
Jozi
Post Thu Aug 23, 2012 10:16 am
Does the over flow catch thing need plumbing in or can I just use the feed and return?
