M42 gearbox
escortade
Hi can any one tell me if the gearbox in a 318is compact is a m42 gearbox, the compact is a 16valve and if not which model BMW they are fitted to. Thanks[/b]
e30-EVN
isnt that the m44??
A 2 door e30 with 8 cylinders, what could be better
escortade
Don't know mate was told that it was a m42 so thought would ask the question
alan1272
i have the compact box fitted to my rally car. it has a direct top gear as opposed to the e30 overdrive top, meaning combined with a 4.1 diff the car will top out at not much over 100mph.
the holes on the output flange are different and the gear linkage and slave cylinder pushrod will need modifying but it will fit, but ensure you consider the gearing before doing it.
escortade
Thanks for your help mate but think I will stick to getting a m42 box
