new lsd diff seals
skooshy
hi guys am doing these the more night any tips?????
skooshy
done them the night piece of pee...... hrs job
I take it that these are the output shaft seals only, as changing the input seal requires that you know exactly what you're doing before you start.
Make sure the output shafts are pushed fully back in, so that the snap rings engage and hold them on. Had a few moments of panic many years ago when the E30 I was due to take on holiday many years ago, suddenly lost all drive as I was backing it out of the garage before I set off.
