E 30 CONVERTIBLE
TSAF
Post Mon Aug 13, 2012 9:25 am
Guys I need your help. I want to fit a hard top. I would like to know which are the best and if I must remove the soft top completely. Your prompt reply will be highly appreciated.
Thanks in Advance
Italian Toys GERMAN WAR MACHINES
T$@F
E30 318i Convertible 1992
X5 3.0 2007
Land Rover Defender 90 4.0 V8
Ianb
Post Mon Aug 13, 2012 10:30 am
There's two choices with hardtops, OEM BMW or Wiessman. The BMW one is more angular in shape and usually vinyl covered ( Removing the Vinyl is possible but at a big cost as the surface beneath is not properly finished ) It's definately worth waiting for one thats already been painted ( even if the colour is wrong ) if you want a painted finish due to the costs involved. The weissman is shaped more like an e36 hardtop and i believe was available in both painted and vinyl. (I have a painted weissman on my car). If you decide to go the weissman route check the seals carefully as i am currently trying to replace mine and not having much luck!
You just put your hood down and remove two rubber bungs to fit the hardtop assuming that yours is an original UK car ( all UK cars had the fittings as standard.
Post Mon Aug 13, 2012 1:38 pm
If you read your handbook, you'll see that BMW recommend removing the soft top completely if the hardtop is to be on for a long period. For shorter periods, such as over winter, it can jut be folded away.
Ianb
Post Mon Aug 13, 2012 3:48 pm
Brianmoooore wrote:If you read your handbook, you'll see that BMW recommend removing the soft top completely if the hardtop is to be on for a long period. For shorter periods, such as over winter, it can jut be folded away.
Good point Brian but I can't imagine why anyone would want one on for longer than "Over winter" Granted they look ok but who would want to drag the dead weight of a cabby plus a hardtop around ......( That would be like fitting a 3.5 boat anchor):mad:
TSAF
Post Mon Aug 13, 2012 6:18 pm
Thanks a lot guys. I believe that a wiseman will be the best way to go. I want to use it only for the winter time (November - April). I am after a mint one so if you know anybody that wants to sell it please let me know.
T$@F
X5 3.0 2007
adit
Post Mon Aug 13, 2012 11:17 pm
Ianb wrote:....who would want to drag the dead weight of a cabby plus a hardtop around ......( That would be like fitting a 3.5 boat anchor):mad:
don't be so ridiculous, they're not THAT heavy!! :teehee:
[quote="bss325i"]
TSAF
Post Tue Aug 14, 2012 8:38 am
Seriously if something comes up, please let me know.
T$@F
X5 3.0 2007
