best suspension set up for alpina staggered
ameetgill1
guys whats the best se up in terms of fixed suspension for the above
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
ameetgill1
thanks guys i have a tech1 cab convertible. recently bought alpina staggered rimd. i may go with h and r or kw. whats billies
Barx325i
bilstein
I'd only get something decent if you're going to use it properly though
ameetgill1
Barx325i
perfect, but I'm in the eibach billstein camp.. Much of a muchness really..
reggid
i find the eibach prokit too soft, a nice ARB set up helps but it doesn't address pitching under braking.
E30 325is with M20B31
Barx325i
if it's a sunday/track fun car then eibach may be a little soft for some people, I had my setup on a daily driver, 80+ miles per day so kw is just down right uncomfortable.. Plus it depends on driving style, an aggressive, hard braking driver would suit harder setup, but I prefer going quicker
ameetgill1
its a every day car i want a smooth and comfortable ride. what do you recommend
Eibach springs and either Bilstein B4 dampers or Boge/Mtech dampers.ameetgill1 wrote:its a every day car i want a smooth and comfortable ride. what do you recommend
ameetgill1
thanks for the help guys last question will the above link be sufficient for what i need as in shocks springs etc. also will the ride be good and be able to go over bumps
Yes, the ride will be a very good standard. Sporty without being bone shaker hard, comfortable and well capable of clearing speed humps with the -35 kit. You'd probably be safe with the 60/40 kit but can't be guaranteed to clear speed humps.
This is my chromie after just being put onto the -35mm Eibach springs
ameetgill1
i have coil overs on at the moment and it is really low. it still clears speed humps the ride is horrendous. the alpinas are 16 inch and the tyres are 205-50-16 and rear is 225-45-16 so 60/4o hopefully will be fine
I'm on 16" rims with 205/50/16 boots in the pic above
ameetgill1
very nice. i think 60-40 for alpina should be a safe bet
