As above really. It turns over fine and is getting fuel and spark. Any ideas?
Engine is from an e34 and I'm using a red label ecu
m50 have spark and fuel but wont start
age
- Formerly twist316
Vanos or non vanos? What is the bosch number on the ECU?
age
- Formerly twist316
Got sorted. Bit ilof soldering on one wire was too weak and had broken.
I was using an m40 box and the prop didn't fit. Did I miss something in the wik???
Jimbob
What prop are you using?
age
- Formerly twist316
i tried a 316i, then a 318i???
Jimbob
Probably need a prop from a 325.
Dave_M3
320 prop fitted in the end
