Spec is as follows;
Cat cam
Refurbished Head with new OEM valve guides
New OEM Rockers and eccentrics
New OEM oil spray bar
BTB 3
Fritzs bits exhaust system
Speedtouch Mild Chip
But as you can hear in the link below it sounds like a typewriter.
Valve gaps are at BMW specification and oil is Mobil Race. 15w 50 (IIRC) was changed last year, went for thicker to try and quiet it down.
I've been told this could be caused by the stainless exhaust but it sounds more from the head itself. From cold it sounds fine but gets worse and worse. Possible tired oil pump? Car has done 110k.
Any ideas would be greatly appreciated as i'm sure it isn't right, I should add on WOT it sounds savage but the rest of the time
