Grrrmachine wrote:While they look the same, 320 and 325 AFMs carry different part numbers to represent the different signals inside. At idle or low RPMs you probably wouldn't tell the difference, but under load a 320 AFM will make a 325 run too lean, and vice versa a 325 AFM will make 320 run rich. It's all to do with the resistance of the carbon track inside, and the signal it therefore sends to the ECU.
It took me two years to work out why my 320 was fouling its plugs, until I checked part numbers and found a 325 AFM fitted.
Interesting. Something i did not know. I had discounted the part number difference as i am well used to the same part carrying more than one number for no reason, they all do it ford, vx, bmw, etc but had only run a car back to back and driven it around the block with both afms.
Odd they would do this as the afm can detect the true air volume with density accounted for so can fuel appropriately from that, ok a b20 would never get the maf fully open but that could be fixed by either a lighter spring or just not looking for such high voltage at the ecu.
Seems an expensive way to solve an issue that can be fixed in the software.
Although i expect its a deeper issue than that when you get into it, these things always are.
Back on topic.
The idle on a m1.3 is always dire the first couple of times its started after battery disconnection, they have a small amount of keep alive memory for the idle settings.
It should however still idle. Just rough.
