i`m thinking of lowering my M50 2dr project car.
What sort of drop could i go without having to add camber adjustment tabs?
Was thinking of a 60/40 drop
unsure of what size tyre to use also.205 55 15 at the min.
The rear sub frame will be coming off anyway so it wouldnt be a prob fitting them.
how low?
Morat
Even at 35mm drop on the back you scrub the inside of the rears before the rest of the tyre - I'd go with the camber plates if I were you.
