Where to buy good quality rear link arms on line
sweep
As above..im after a gerry pair of good quality
Barx325i
rear arb drop links? there was something about mondeo (possibly) rose jointed type which fit.. I could be completely wrong tho
sweep
Rear ones yes
ajay
Are you using a standard arb or up ratted(adjustable)?
sweep
eibach ones mate
ajay
Ground control e30 rear arb adjustable drop links for upratted arb,s only. Can be purchased from ca automotive.
Mondeo (rear, estate, 2000) drop links replace the front ARB links on an E30. I've just tried this mod. for the first time, and they fit perfectly. They aren't rose jointed - they just have two ball joints similar to the upper one on the E30 part, eliminating the lower rubber bush, which is always the part that fails.Barx325i wrote:rear arb drop links? there was something about mondeo (possibly) rose jointed type which fit.. I could be completely wrong tho
For rear links: http://www.carparts4less.co.uk/anti-roll-bar-components
Barx325i
Cheers for the clarification Brian, I may go this route..
Mondeo link to replace E30 front: http://www.carparts4less.co.uk/cp4l/c/F ... 53a&000016
