rev drop?
cro320
Wed Jul 25, 2012 10:11 pm
Lately my 1990 320i behaves strange
when I drive slow with clutch up and around 1200 rpm and then press it and stop the engine drops idle like it get's in some kind of stall mode and when I try to move in first it jerks a bit and then pulls off, and after that drives like a dream. Parking becomes very annoying because of this, car stalls if I do't pump the gas all the time...
what should I check? Also when fully warmed and idling I can notice very slight movement up n down of rpm needle and engine changes tone slightly?
Billwill
Thu Jul 26, 2012 11:45 am
cro320 wrote:Lately my 1990 320i behaves strange
Sounds like your clutch may not be releasing properly so it puts strain on the engine even when the clutch pedal is pressed in. :?
cro320
Thu Jul 26, 2012 2:55 pm
clutch is almost new
Billwill
Sat Jul 28, 2012 3:26 pm
Are the clutch slave and master cylinders new? :?
