Oil Pressure
cypriot_boy_2k7
Post Thu Jul 19, 2012 4:28 pm
How much pressure is in the sump when the cars started?
For an M40
BenHar
Post Thu Jul 19, 2012 4:45 pm
One bar.
Ben
ross2009
Post Thu Jul 19, 2012 7:50 pm
you on about crank casing pressure or actual oil pressure ?
Turbo M20
v8 project 6.0 twin turbo
cypriot_boy_2k7
Post Thu Jul 19, 2012 8:26 pm
ross2009 wrote:you on about crank casing pressure or actual oil pressure ?
actual oil pressure in the sump only, had a lil mess up with my oil return on the sump, drilled a bit of a big hole on the sump, all sealed with copper washers and tested by filling it up with water no leaks but I don't know if it will hold under pressure.
ross2009
Post Thu Jul 19, 2012 8:27 pm
there shoudnt really be hardly any pressure on the return its just s drain
Turbo M20
cypriot_boy_2k7
Post Thu Jul 19, 2012 8:56 pm
Is Ben's info wrong?
ross2009
Post Thu Jul 19, 2012 8:58 pm
look at it this way when you undo the oil filler cap is it pressurised ??????
Turbo M20
cypriot_boy_2k7
Post Thu Jul 19, 2012 10:42 pm
ross2009 wrote:look at it this way when you undo the oil filler cap is it pressurised ??????
Very good point
Post Fri Jul 20, 2012 12:03 am
Pressure in the sump is negative with respect to atmosphere. That's why the engine idles rough when you take the oil filler cap off.
BenHar
Post Fri Jul 20, 2012 11:13 am
The pressure may be lower than atmospheric when it is running but one bar (one atmosphere) is the max it will go to. That will be when it is not running.
Ben
