I'm going to fit a new water pump but there always seem to be two available. They look identical but one has a brass type impeller (make - KWP) and the other has another type of metal (make - Circoli).
The brass one is £15 more expensive.
Which is the best to fit?
Which water pump?
If you enjoy doing the same job over and over again, plus repairing the damage that a failed pump can do, go for the cheaper one. If you want a pump that will probably last the rest of the life of your car, go for the KWP one.
It's an unfortunate fact of modern life that most factors offer parts for the " fix it up cheap and sell it on quick brigade" as well as for those that take pride in doing a job properly.
DanTheDoc
Thanks again for the advice, the more expensive one it is then. The missus need not know there is a cheaper alternative!
Andyboy
- Alpina Colada
To be fair, I've used Circoli M50/52 pumps and they've been fine. Best of all are the BMW ones - yours has possibly been on there 15-20 years. They are about 100 quid, but........
