Hi I have a 1989 325i convertible just the other day a mate told me that a ignition lead with a attached lead which plugs into a sensor or so is cut. Anyone have any idea of what this actual lead does please?
1989 325i ignition leads question help
cecotto479
- Caution Unreliable Seller
It tells the ECU which set of three injectors to fire. If it doesn't get a signal from the sensor, it fires them all. Your car will run perfectly well without it. It may use marginally less fuel with it connected.
1981 E23 735i
Grrrmachine
- E30 Zone Wiki / Team Member
