For following parts, Cheers!
31351127202 E30 Cab Support Shackle 2
07119903039 E30 Cab M8x20 Hex Bolt 2
07119904032 E30 Cab M8 Hex Nut 2
33111210405 Z3M Diff Gasket 1
07119914114 Z3M M10x25 Hex Bolt 2
07119921541 Z3M M10x75 Hex Bolt 2
07119921522 Z3M M10x85 Hex Bolt 4
07119932112 Z3M B10 Washer 8
27101220647 Z3M M12x1.5 Hex Bolt 1
07119931021 Z3M A13 Washer 2
07129900047 Z3M M12 Locking Nut 1
33172228297 Z3M D=25MMX15MM Bush 4
34116772428 Z3M M12X1,5X32 ZNS3 Collar Screw 4
33172228425 Z3M Rubber Mounting 1
16121179681 E30 318i Fuel Supply Line 1
16121179682 E30 318i Fuel Return Line 1
11731717849 E30 318i Breather Pipe 1
07129952104 E30 318i Hose Clamp 3
33117525064 Z3M Screw plug with O ring 2
07119963355 Z3M Gasket ring 2
Quote Please
Cotswoldbmw
Hi There
31351127202 E30 Cab Support Shackle 2 £6.94 for 2
07119903039 E30 Cab M8x20 Hex Bolt 2 £1.72 for 2
07119904032 E30 Cab Hex Nut 2 £0.76 for 2
33111210405 Z3M Diff Gasket 1 £2.30
07119914114 Z3M M10x25 Hex Bolt 2 £3.88 for 2
07119921541 Z3M M10x75 Hex Bolt 2 £14.50 for 2
07119921522 Z3M M10x85 Hex Bolt 4 £7.22 for 4 German order
07119932112 Z3M B10 Washer 8 £1.21 for 8
27101220647 Z3M M12x1.5 Hex Bolt 1 £3.43 German order
07119931021 Z3M A13 Washer 2 £0.64 for 2
07129900047 Z3M M12 Locking Nut 1 £0.77
33172228297 Z3M D=25MMX15MM Bush 4 £13.66 for 4 German order
34116772428 Z3M M12X1,5X32 ZNS3 Collar Screw 4 £8.30 for 4
33172228425 Z3M Rubber Mounting 1 £85.51
16121179681 E30 318i Fuel Supply Line 1 £21.59
16121179682 E30 318i Fuel Return Line 1 £21.59 German order
11731717849 E30 318i Breather Pipe 1 £3.78
07129952104 E30 318i Hose Clamp 3 £2.05 for 3
33117525064 Z3M Screw plug with O ring 2 £8.20 for 2
German orders 3-5 working days
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 55344
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
