Steering UJs
dooce
Anyone have an idea as to what the longer steering linkage is this pic is used on? I have several laying about, but they are all the shorter version expect for this one. My LHD touring has the shorter one as well, so I can rule that out. Certain years? The only other difference is the splined hole that would be around the column is a smaller diameter than the other.
dooce
Oh, I cannot find a part number to cross reference realoem with either.
jimmyspeed
power steering and non power steering are different lengths on a e30
dooce
but aren't all the columns the same? why would it be a smaller hole for the column?
jimmyspeed
the ends near the steering guibo should be the same - the spline to the manual rack is smaller
might be something to do with the left hand drive but i've never seen one so can't say
Barx325i
good Q, but you may have measured the wrong end - the cup opening faces upwards, as in the longer manual version in the pic above is how it should be installed. The PAS version on the left is upside down in comparison so the spline you may have measured is be the rack spline - smaller than the column end.. easy possible oversight..
dooce
OK I will check it out tomorrow, but that is probably what has happened. Thanks for the help!
Barx325i
gotta be really.. hth
- **BANNED**
When I converted my touring from LHD to RHD,the column coupling was one part that I could re-use!
Youth is wasted on the young.
