Quick brake question
Checkmate
Post Sat Jul 14, 2012 9:54 pm
So I need a couple o calipers for my 325i track car, after the bleed nipples sheared on both nearside calipers. It's a coupe, I was wondering wether the calipers are all the same on all body shapes, as some appear to be listed differently. It's a 1987 model if that makes any difference. Thanks.
**BANNED**
Post Sat Jul 14, 2012 9:58 pm
Front calipers are the same across all proper engined cars.
Rear calipers vary between saloon/cabbie/touring,saloon/cabbie are the same,but tourings have a slightly larger piston.
No 'coupe' variant,BTW,just 2 door and 'more door' saloons!
Youth is wasted on the young.
Checkmate
Post Sat Jul 14, 2012 10:05 pm
Just the answer I was looking for, thanks.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jul 15, 2012 8:26 am
If it helps, a handy trick is to get a small torx bit and tap it into the leftovers of the bleed nipples. The teeth should bite in enough to allow you to remove the remnants, so that you don't need to find new calipers.
