VIN Location
sgaites
Post Sat Jul 14, 2012 9:44 am
Does anyone know if the VIN is stamped in the bodywork anywhere other than the scuttle panel under the windscreen?
Need urgent advice as the car is being re-tested tomorrow and no dealer or bodyshop would re-stamp the VIN (scuttle panel has been replaced).
Post Sat Jul 14, 2012 9:50 am
Not stamped in the bodywork anywhere else, but stamped into a plate that should be above the back of the RH headlamp, and, on later models, on a label on the engine ECU.
sgaites
Post Sat Jul 14, 2012 9:56 am
Thanks, but it needs to be stamped into the bodywork for the test. Plates and stockers can be removed. Cheers
Post Sat Jul 14, 2012 10:10 am
Not so. A riveted on plate is sufficient.
The M.O.T. Inspection Manual Issue Date 01 January 201
"5. Check that the vehicle is permanently displaying a legible Vehicle Identification Number. This can be either: · on a VIN plate secured to the vehicle, or · stamped or etched on the vehicle body or chassis."
sgaites
Post Sat Jul 14, 2012 11:04 am
I'm in Ireland.
**BANNED**
Post Sat Jul 14, 2012 12:00 pm
Do you still have the old scuttle panel?
Youth is wasted on the young.
sgaites
Post Sat Jul 14, 2012 1:21 pm
No afraid it wasn't me that changed it.
Post Sat Jul 14, 2012 1:29 pm
The only thing I can suggest is that you beg, borrow or otherwise acquire a set of number and letter punches and stamp it in somewhere.
I don't know the details of the Irish version of the MOT, but consider stamping it on a separate sheet of steel and MIGing it to the shell.
