leaking heating system
xavier
Post Wed Jul 04, 2012 5:21 am
I have a leak with the heating system. it is just to the right of the central tranmision tunnel. Is there a point they normaly leak from? if it is just a few seals it is not too hard a fix, but if the matrix needs replacing it all gets a bit more involved.
Is there any way to check the matrix?
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jul 04, 2012 6:15 am
First thing to check is the stub pipes. Although these are on the other side of the matrix, fluid leaks can be funny things so it's essential to confirm the real source of the problem.
http://www.e30zone.net/e30zonewiki/inde ... Stub_Pipes
