i know its not an e30 but i need help with my e34 no spark
muraska
Post Fri Jun 29, 2012 6:48 pm
Hi guys looking for some advice as i'm banging my head of the wall, i dropped a couple of the nuts from the coil packs down beside the ecu in my 95 525is so i moved the ecu from the box( without unplugging it) it sits in then i removed the box and retrieved the nuts put every thing back together but now i have no spark at the plugs, any ideas
Post Fri Jun 29, 2012 7:03 pm
Does the fuel pump run when cranking the engine?
muraska
Post Fri Jun 29, 2012 7:14 pm
yes the fuel pump runs
muraska
Post Fri Jun 29, 2012 8:25 pm
scrub that no fuel either
bmpaul
Post Sat Jun 30, 2012 4:19 pm
I take it everything is plugged back in as it should be, main ecu plug securely on and all the coil plugs on properly and all the earth straps on as well? Sounds simple but easiest things first!
E39 530d M-sport- quite nippy
