Hey guys. my diff has become noisy and quite lumpy on take off. How long do i have before it viciously locks my wheels and i go plowing into the nearest hedge/lamp post/group of hippy extremists?
Diff whine!
yung-gun
Is it an open diff, or an LSD? Open diffs can rumble on for years with lots of wear - try refilling it with a thicker grade oil to quieten it down a bit.
yung-gun
Grrrmachine
- E30 Zone Wiki / Team Member
Is it a squealing mosquito whine or a throaty groaning rumble? And how have you determined it's the diff? You can get all sorts of rear end noises on old cars, and something two mechanics told me was a knackered diff turned out to be a sticky handbrake!
If it IS a failing diff, they can last for years without a change but you'll be driving with clenched buttocks for a long long time, waiting for it to pack up.
yung-gun
Got the car on a 4 poster. jacked the back end up. Block of wood under 1 wheel, 4th gear clutch out build the revs dump the clutch and it's whining it's head off and did the same on the other side just to make sure it wasn't wheel bearing. and you can see the drive shaft on the diff end rotating as though it's egg shaped. it sounds like the back end of a bus type of whine!
In that case, probably best to change it for a better one.
yung-gun
HairyScreech
Potentially not long at all, had a bad one fail on the m4 in the space of 5 miles.
If your 100% on it being bad then its hand brake turn russian roulette time.
yung-gun
