What could be causing this? I've tried twisting it in a bit but its at too much of a angle to line up
Rear Anti Roll Bar fitment issue
Jim320i
- E30 Zone News / COTM Team
I'm in the process of putting a rear anti roll bar on my 320i, the bar is in place, the passenger side droplink is attached up the trailing arm, but the driver side does not sit straight when I put the drop link in the bracket?
Grrrmachine
- E30 Zone Wiki / Team Member
Have you read the fitting guide, just to make sure you've got the bar the right way round and suchlike?
http://www.e30zone.net/e30zonewiki/inde ... g_Rear_ARB
Jim320i
I read it, then went to check earlier, but it seems my bar is short on both sides rather than having a longer straight than one side? The bar was removed from the 325es I got sitting up here.
I removed it with no problem, but forgot to take note of how it sat...
