vibrations through the floor
jonny323i
Post Sun Jun 24, 2012 11:16 am
iv got vibrations when idling or if i rev the engine coming through the floor and peddles iv replaced engine and gearbox mountings and i cant seem to find anything catching on the body. The vibrations are at stand still so i dont think it can be the prop bearing as this is with the car out of gear
325i by the way tourer
Touring for life
Post Sun Jun 24, 2012 11:32 am
Does it idle rough?
jonny323i
Post Sun Jun 24, 2012 11:41 am
it did but thats mostly cured now
Touring for life
Curr946
Post Sun Jun 24, 2012 11:49 am
is the exhaust close to the floor under the drivers floor pan?
If your wife must learn to drive, don't stand in her way!
jonny323i
Post Sun Jun 24, 2012 12:52 pm
no mate i dont know why i think this but im not sure what condition the clutch is in and im wondering if its degrading and causing excess vibration
Touring for life
Post Sun Jun 24, 2012 1:59 pm
Could be a loose flywheel!
jonny323i
Post Sun Jun 24, 2012 2:14 pm
that serious has that been known the reason i wondered about the clutch is i know the sump gasket was leaking when i had it which is now sorted but i think oil got into it
Touring for life
Post Sun Jun 24, 2012 10:35 pm
Yes, happened to gareth on here, I think he had clutch judder which made him pull the box off. Either way if your engine and gearbox mounts are normal rubber type and the exhaust is mounted properly you shouldnt have vibrations like that
jonny323i
Post Tue Jun 26, 2012 6:27 pm
Is it just a case of tightening it up or am I in trouble if it is loose
Touring for life
Post Tue Jun 26, 2012 7:17 pm
If its loose you need to take the bolts out and inspect them, then loctite them back in to the correct torque
jonny323i
Post Tue Jun 26, 2012 8:29 pm
do you happen to know what setting that is
Touring for life
