no ground on ecu pin 2
SGP
Post Fri Jun 22, 2012 11:51 pm
While checking the ecu connections the other day I noticed pin 2 of the ecu loom plug is not grounded, which it should be according to all the pin out charts :
http://www.e30zone.net/e30zonewiki/inde ... tronic_1.1
I was wondering if it's switched by the ecu or have I got a problem and if so, where to start ?
(b20 381 ecu)
If it ain't broke..
Fix it till it is :)
