5 stud vs 4 stud
rich318i
are there any plus points to a 5 stud conversion or just a waste of money?
penton08
Most people do it for a larger choice of wheels, if you go down the e36 evo route you get big brakes for free!!
shanehaward
would it be cheaper and easier to get some hub adaptors? atleast then you could pick and choose between wheels 4x100 vs 5x120
also would you be able to use mk2 golf adaptors or is the centre bore different?
Motorhole
More track 20mm each side, bigger & stronger front wheel bearings. E36 M3 brakes are mahoosive on an E30, 312mm discs and 60mm pistons.
ajay
Also drop links hinge from the legs insead of the wishbones,better control although you can modify 4stud legs to achive the same results.
